KB87351
Published: May 24, 2018
OptoDataLink: "Database INSERT transaction failed/Number of values and fields not the same" when Single Sample option isn't selected
R9.6a through R9.6c; and Beta version B9.6d, all builds through 0013
R10.0a
If the Single Sample check box isn't selected when the source is an Opto 22 Device table (Edit > Add New Data Link > Data comes from an Opto 22 Device Table) , OptoDataLinkRuntime will display an "Error in [link name]: Database INSERT transaction failed. Reason: Number of query values and destination fields are not the same" message when the link tries to run.
- Open your OptoDataLink's project file in a text editor. The project file has a file extenson of .xml (for example, WeatherData.xml).
- In the file, each link that comes from an Opto 22 Device Table will have these two lines:
<sendIndex>False</sendIndex>
<sendTimestamp>False</sendTimestamp>
You can use the text editor's Find feature to find the lines.
- Replace all instances of those lines with these:
<sendIndex>True</sendIndex>
<sendTimestamp>True</sendTimestamp>
- Save the file, restart the project in OptoDataLink, and then run the links.
