KB87565
Published:
Modules disappear or appear incorrectly after hotswapping another module
GRV-EPIC-PR1
1.0.0, 1.0.1
1.2.0
After you hotswap a non-simple, digital module, you might see any of the following behaviors in the Modules page of groov Manage:
  • a simple, digital module in another slot disappears
  • a simple, digital module appears in a slot where there is no module
  • a simple, digital module appears in a slot where there is another, non-simple module
In all of these cases, the module LEDs do not change color.
Note: Hot-swapping a module means removing and/or adding a module while the GRV-EPIC-PR1 is turned on.
Do not hotswap modules after you started your GRV-EPIC-PR1.
