KB87606
Published:
Revision: 1.1
Opto 22 application logs use up excessive disk space
Firmware for GRV-EPIC-PR1
1.0.0, 1.0.1
1.1.0
You might see any of the following:
- Excessive disk usage.
- Failure to boot if partition is filled to 100%.
- Progress bar on boot will get to approximately 75% and stop.
- groov Manage will fail to start.
- Other Opto 22 services may fail to start.
- Any log, excluding Operating System logs, exceeds 20 MB when downloaded through groov Manage.
Review your error logs and make sure to resolve errors, particularly those that write to the log frequently (for example, once per second).
