KB87647
Published:
Revision: 1.1
Errors in GRV-EPIC-PR1 control engine message queue and communication to I/O unit disabled
Firmware for GRV-EPIC-PR1
1.0.0, 1.0.1, 1.1.0
1.2.0
If your PAC Control strategy has a groov I/O unit and you configure an analog input channel with the Default field set to "Yes", then when you run the strategy, errors will be placed in the control engine's message queue and communication to the I/O unit will become disabled.
Select "No" for the Default field on analog input points.
