KB87669
Published: May 10, 2019
Clamping a persistent variable or table element may disable the PR1 control engine
Firmware for GRV-EPIC-PR1
  • PAC Control Engine
1.0.0, 1.1.1, and 1.3.0
1.3.1
If you use any of the following PAC Control commands to clamp a persistent variable, then the GRV-EPIC-PR1 control engine may become disabled:
  • Clamp Integer 32 Variable
  • Clamp Integer 64 Variable
  • Clamp Float Variable
  • Clamp Integer 32 Table Element
  • Clamp Integer 64 Table Element
  • Clamp Float Table Element
