KB87682
Published:
All groov I/O module LEDs turn red and OptoMMP server is unresponsive
Firmware for GRV-EPIC-PR1
1.0.0, 1.0.1, 1.1.0
1.2.0
If your control program writes to the Stream Configuration area (0xF03FFFC0) of the memory map, all groov I/O module LEDs on the groov EPIC chassis will turn red and the OptoMMP Server becomes unresponsive. Note that this problem persists through power cycles.
Avoid writing to the Stream Configuration area.
You may have to contact Opto 22 Product Support for help with this problem.
