KB87718
Published:
Revision: 1.1
I/O configuration of simple output module remains after swapping with another module
Firmware for GRV-EPIC-PR1
1.0.0, 1.0.1, 1.1.0
1.2.0
If you mount a simple output module on a groov EPIC chassis, then you remove it and replace it with any other type of module, the I/O configuration of the simple output module remains; it does not get replaced by the I/O configuration of the new module.
