KB87719
Published:
Time difference between GRV-EPIC-PR1 and Control Engine
Firmware for GRV-EPIC-PR1
1.0.0 through 1.2.2
1.3.0
The control engine on groov EPIC processor doesn't apply the current time zone offset to the hardware clock.
If a time zone other than UTC is set on a groov EPIC processor (via groov Manage), the time retrieved by the control engine will be off by the offset of the currently-set time zone. In addition, attempting to set the date/time using PAC Control strategy commands, PAC Terminal, or PAC Display will result in the clock being set to unpredictable values.
  • Always set the date and time through groov Manage.
  • When you retrieve date and time values through a strategy, manually apply the current time zone offset.
