KB87781
Published:
External HDMI touchscreen monitor may not work properly after rebooting the GRV-EPIC-PR1
Firmware for GRV-EPIC-PR1
All versions
If an external HDMI touchscreen monitor is connected to the GRV-EPIC-PR1, then if you reboot the GRV-EPIC-PR1, you may see the following:
  • The touchscreen does not respond to any touches.
  • There are lines of different colors across the screen.
Disconnect the HDMI cable from the GRV-EPIC-PR1 and then reconnect it.
