KB87815
Published:
Uploading an SSL certificate without the private key file fails without error
Firmware for GRV-EPIC-PR1
  • groov Manage
1.0.0 through 1.2.2
1.3.0
In groov Manage, when you upload an SSL certificate without uploading the corresponding private key file, groov Manage displays a message that it will restart the browser for changes to take effect. However, the browser does not restart groov Manage, the new certificate is not saved, and the previous certificate remains in use.
Always upload the private key with the certificate, even if it is the same as the currently installed private key. The currently installed private key can be downloaded from groov Manage > Security > Server SSL > Download Private Key.
