KB87885
Published: April 16, 2019
Get Analog Totalizer Value Returns -1.#QNAN in PAC Control
Firmware for GRV-EPIC-PR1
1.0.0 through 1.3.0
1.3.1
In a PAC Control strategy, you must first use the Set Analog Totalizer Rate command before using the Get Analog Totalizer Value command. If the analog point is on a GRV-EPIC-PR1 I/O Unit, the Get Analog Totalizer Value command returns -1.#QNAN instead of the totalized value.
After using the Set Analog Totalizer Rate command, immediately use the Get & Clear Analog Totalizer Value command once. The Get Analog Totalizer Value command will work correctly after that.
