KB87887
Published: October 3, 2019
Cannot Enable Communication to EPIC I/O Unit in PAC Control Strategy
Firmware for GRV-EPIC-PR1
1.2.1 through 1.2.2
1.3.0
When you configure offset and/or gain values for an EPIC I/O Unit in a PAC Control strategy (using the Send Values checkbox), then when you run the strategy, the control engine will not be able to enable communication to the I/O Unit.
Uncheck the offset/gain send value checkbox. Then use groov Manage to configure offset and gain.
