KB87915
Published:
Control engine stops working
Firmware for GRV-EPIC-PR1
1.2.0 through 1.2.1
1.2.2
After about 20-30 days, the control engine on the GRV-EPIC-PR1 may fail.
Do one of the following:
- In groov Manage, go to Home > Control Engine, and then disable the control engine. When it indicates it is disabled, then enable the control engine.
- In groov Manage, go to Home > System, then Restart.
- Reboot the unit by using the power switch: turn it off, wait about 15 seconds and then turn it on.
