KB87920
Published:
Store Strategy to Flash sometimes fails
The control engine shipped with firmware for GRV-EPIC-PR1.
1.0.0 through 1.2.1
1.2.2
If you store a strategy to flash, then subsequently modify it and save it to flash again, cycling power may load the previous strategy instead of the most recently saved strategy.
  1. In PAC Control Debug mode, go to Control Engine > Inspect and disable the auto-run flag.
  2. Switch to PAC Control Config mode.
  3. In groov Manage, from the home screen, click Control Engine and then click Disable to disable the control engine.
  4. Wait until groov Manage indicates that the control engine is disabled.
  5. Click Enable to re-enable the control engine.
  6. In PAC Control, download your modified strategy.
  7. If the strategy wasn't configured to automatically store to flash during download, then store the strategy to flash.
