KB87935
Published:
Uploading a file or system update may fail
Firmware for GRV-EPIC-PR1
  • groov Manage
1.0.0 through 1.2.1
When you do either of the following, it may fail:
  • Uploading a file (groov Manage Home > System > Files)
  • Running a system update (groov Manage Home > Maintenance > Update > Update System)
Attempt the upload or system update again.
