KB87970
Published: April 17, 2019
Can't connect to control engine on GRV-EPIC-PR1 after disabling and re-enabling control engine in groov Manage
Firmware for GRV-EPIC-PR1
All versions prior to 1.3.1
1.3.1
When you try to connect to the control engine on a GRV-EPIC-PR1 after you disabled and then re-enabled the control engine through groov Manage (Home > Control Engine, then tap or click Disable, then Enable), you may get a timeout error.
In groov Manage, disable the control engine (Home > Control Engine, then tap or click Disable), wait 30 seconds, and then enable the control engine (tap or click Enable).
