KB87974
Published:
groov module LED stay violet when module firmware update fails
Firmware for GRV-EPIC-PR1
Loader for the following groov I/O modules:
  • GRV-IAC-24
  • GRV-IACDCTTL-24
  • GRV-IACHV-24
  • GRV-IACI-12
  • GRV-IACIHV-12
  • GRV-IDC-24
  • GRV-IDCI-12
  • GRV-IMA-24
  • GRV-ITMI-8
  • GRV-IV-24
  • GRV-OAC-12
  • GRV-OACI-12
  • GRV-ODCI-12
  • GRV-ODCSRC-24
  • GRV-OVMALC-8
1.0.0 through 1.2.2 for GRV-EPIC-PR1
Loader versions earlier than 1.1a for modules
1.3.0
When you update firmware on any of the listed modules, but you upload an incorrect file (for example, you try to upload the firmware file for a GRV-IAC-24 module to a GRV-IACI-12 module), groov Manage displays an error message, but the module does not automatically recover.
You can do either of the following:
  • After you clear the error message in groov Manage, upload the correct firmware file. The module LED will clear and return to normal after the firmware update is a success.
  • Remove, then remount the module. Retry the module firmware update with the correct file.
