KB87987
Published: April 17, 2019
IVAL may not update if PAC Control strategy was not run
Firmware for GRV-EPIC-PR1
All versions prior to 1.3.1
1.3.1
In the PAC Control debugger, when you inspect a GRV-EPIC-PR1 I/O unit, changes made to individual IVALs will show a change only in the individual point window, not the module window view, until the GRV-EPIC-PR1 I/O unit has run at least once.
Before manually changing an IVAL, either run the strategy or enable the I/O unit at least one time. You will then be able to see the values update in both windows when you change it in the individual point window.
