KB87993
Published:
Wires get duplicated when installing missing node types.
groov products including:
- GRV-EPIC-PR1
Any installation of Node-RED.
Node-RED 0.17.4.
This bug in Node-RED ONLY affects nodes of the same type that are connected together, and only when a project is used in a Node-RED instance that does not yet have the nodes installed.
Opto 22 users are somewhat likely to see this issue because:
- They may chain our PAC or Groov nodes together, when reading multiple values in a series.
- They may restore a Node-RED project to a different device.
- After updating a PR1, the user MUST restore their Node-RED project and install any missing flows.
After restoring or moving a Node-RED project and then installing missing nodes, there may be hidden duplicate wires between nodes. This cannot be easily seen, because the duplicate wires are on top of each other.
The duplicate wires cause messages to be duplicated, as if they were going to multiple nodes.
If more than two of the same node are chained together, then the wire and message duplication will grow exponentially.
Other possible symptoms:
Our nodes have an internal message queue mechanism that can hold 1000 messages waiting to be processed. In one case, a user had 8 or 9 PAC Read nodes chained together so the message queue filled quickly.
Once affected:
- Delete and replace wires OR
- Edit the project file's JSON (advanced users only)
To avoid:
- After installing missing nodes, refresh the browser.
