KB88034
Published: August 19, 2019
Restore from backup fails if NTP configured with no time servers
Firmware for GRV-EPIC-PR1
All versions prior to 1.4.0
1.4.0
If your groov EPIC processor has NTP enabled, but no time servers specified, and you create a backup file with this configuration, then when you try to restore this backup, the restore fails.
- Make a copy of your backup.
- Unzip your backup and edit the file time/time.json.
- Do one of the following:
- If you want to disable NTP, change the serviceEnabled to false.
"ntp": {
"serviceEnabled": false
"zone": {
"timezone": "Universal"
- If you want your groov EPIC processor to make requests to a time server, include at least one time server. The time server can be external or it can be a time server on your local network, if there is one. The following example shows the format to use, and how to add three time servers:
"ntp": {
"serviceEnabled": true,
"timeServers": [
"peerType": "pool",
"address": "0.pool.ntp.org"
"peerType": "pool",
"address": "1.pool.ntp.org"
"peerType": "pool",
"address": "2.pool.ntp.org"
"zone": {
If you want to create another backup file and prevent this issue (until it's fixed), add a time server (from groov Manage Home page, click System > Time) which points to either an external time server or a time server on your local network, then create a new backup file.
