KB88036
Published: April 17, 2019
Changing the clock may result in interruption of established sessions
Firmware for GRV-EPIC-PR1
All versions prior to 1.3.1
1.3.1
If you have any established communication session with the groov EPIC procesor, then you change the processor's clock through groov Manage (Home > System > Time), your established sessions may be interrupted.
Avoid changing the processor's clock while communication is in progress.
