KB88073
Published: April 17, 2019
Port Forwarding to TCP Port 443 on GRV-EPIC-PR1 Doesn't Work
Firmware for GRV-EPIC-PR1
All versions prior to 1.3.1
1.3.1
If you set up a device like a router to forward a request from a client to the GRV-EPIC-PR1, the client will not be able to reach the GRV-EPIC-PR1.
Do not use port forwarding.
