KB88083
Published: February 25, 2020
Revision: 4.0
"Is I/O Unit Ready?" command always shows groov I/O as ready
Firmware for:
  • GRV-EPIC-PR1
  • SNAP-PAC-S2, SNAP-PAC-S2-W
  • SoftPAC
GRV-EPIC-PR1: all versions prior to 1.3.1
PAC Firmware: R10.0d or higher to R10.og
GRV-EPIC-PR1: 1.3.1
PAC Firmware: R10.0h
If your PAC Control strategy uses the "Is I/O Unit Ready?" command to test for a groov I/O unit, the result will always be true, even if no I/O unit is connected. In addition, you may see errors in the Message Queue.
