KB88091
Published: April 17, 2019
Incorrect Values Returned When Reading Digital Input Feature Data from Packed Data Area of Memory Map
Firmware for GRV-EPIC-PR1
All versions prior to 1.3.1
1.3.1
If you configured any full-featured digital input channels for one of the features (for example, counting, On/Off Pulse, Frequency, Period, On/Off Totalizing, or Quadrature), then read the related data for that channel from the Analog EU or Digital Counter (Feature) Packed Data area of the memory map (base address 0xF1001000), the data won't be correct.
Read the digital input feature data from other areas of the memory map.
