KB88104
Published: February 25, 2020
Revision: 4.0
Setting groov Digital TPO to Zero Percent Doesn't Stop Pulsing
Firmware for:
  • GRV-EPIC-PR1
  • SNAP-PAC-S2, SNAP-PAC-S2-W
  • SoftPAC
GRV-EPIC-PR1 firmware: All versions prior to 1.3.1
PAC Firmware: R10.0a to R10.0g
GRV-EPIC-PR1 firmware: 1.3.1
PAC firmware: R10.0h
In your PAC Control strategy, when you use the Set TPO Output command with a value of zero, it should stop the TPO. However, for groov digital output modules, it does not.
Use the PAC Control "Turn Off" command to stop the TPO.
