KB88158
Published: April 1, 2020
Can't assign certain system tags to some gadget types
groov View running on the following:
  • GRV-EPIC-PR1
  • GROOV-AT1, GROOV-AT1-SNAP
1.3.0 to current for GRV-EPIC-PR1
4.1a to current for all others
1.3.1 to current for GRV-EPIC-PR1
4.1b to current for all others
In groov View Build mode, within the System device, when you try to add the groov/Heap Usage (MB), groov/ groov CPU Usage (%), or Operating System/System CPU Usage (%) tags to any of the following gadgets, groov View doesn't let you, even though it should:
  • Level Indicators
  • Round Gauges
  • Range Indicators
  • Trends
