KB88226
Published: April 17, 2019
Control engine keeps trying to access a groov I/O unit that is offline
Firmware for GRV-EPIC-PR1
All versions prior to 1.3.1
1.3.1
If the control engine gets an error when trying to communicate to a groov I/O unit, the control engine should disable communication to that groov I/O Unit so that the control engine doesn't repeatedly time out trying to access the non-responsive I/O. However, this is not happening on groov I/O units.
If you are testing a system that doesn't yet have the groov I/O Units, configure those I/O Units as Disabled and do not enable communication to them in the PAC Control debugger or in strategy logic.
