KB88237
Published: May 16, 2019
PAC Control Engine on GRV-EPIC-PR1 occasionally fails to start
Firmware for GRV-EPIC-PR1
All versions prior to 1.3.2
On rare occasions, the PAC control engine may not start. groov Manage may show that the control engine is running; however, you won't be able to access the control engine via its host task (for example, with PAC Control or PAC Terminal).
Restart your groov EPIC processor (Home > System > Restart).
