KB88242
Published: May 5, 2020
Open Outgoing Communication returns -10 error
Firmware for GRV-EPIC-PR1
All versions to .1.5.0
2.0.0
The Open Communication Handle command will return a -10 status code in your PAC Control strategy if you are connecting a USB-to-serial adapter to:
- one USB hub which is then plugged into a second USB hub that is then plugged into a USB port on the GRV-EPIC-PR1, or
- a large USB hub (that internally contains a second USB hub to provide more ports) that is then plugged into a USB port on the GRV-EPIC-PR1.
