KB88290
Published: May 17, 2019
GRV-OVMAILP-8: If hot-swapped, could cause continuous resetting of PR1
Firmware for GRV-OVMAILP-8
All versions
In a few cases, if you have a GRV-OVMAILP-8 module mounted on a groov EPIC chassis, you may observe the following behavior:
- When the groov EPIC I/O unit is powered-up, the GRV-EPIC-PR1 does not discover the GRV-OVMAILP-8 module or the groov EPIC processor resets.
- When you hot swap a GRV-OVMAILP-8 module, the groov EPIC processor may reset.
