KB88370
Published: February 19, 2021
groov View Fails to Load or Does Not Allow User to Log In
groov View running on:
All versions prior to 4.3a
4.3a
On a GROOV-AR1, if the system time is set to a time or date in the past before creating users, groov View does not allow the users to log in, or it shows a blank View page.
On older versions of groov View, you are redirected back to the login page with an error. On newer versions, you see a blank groov View screen.
Be sure the time and date are set correctly in the system time.
