KB89070
Published: December 9, 2020
Whitespace Surrounding Strings is Trimmed During Writes
Firmware for:
  • GRV-EPIC-PR1
  • GRV-R7-MM1001-10
GRV-EPIC-PR1: Version 1.4.0 to 2.0.2
GRV-R7-MM1001-10: All versions prior to 3.0.0
GRV-EPIC-PR1: 3.0.0
GRV-R7-MM1001-10: 3.0.0
When the groov EPIC MQTT client processes string writes to the memory map or to the control engine, it removes the leading or trailing whitespace characters. This is incorrect behavior.
