KB89263
Published: December 23, 2020
Enable Quality Indicator Option Missing for Some Digital Channels in Edit Digital Point Window
- PACCONTROLBAS (PAC Control Basic)
- PACCONTROLPRO (PAC Control Professional)
R10.3c
R10.3d
In PAC Control Config mode, when you edit a digital channel (of a groov I/O module or a RIO) in the Edit Digital Point window, PAC Control does not display the Enable Quality Indicator option for full-featured digital channels (channels that are not simple or not mechanical relays).
Enable or disable the digital channel's quality indicator through groov Manage.
- Log into the groov EPIC or RIO module with an administrator account.
- Go to digital channel's configuration page:
- On a groov I/O module: Click I/O > the module > the digital channel > Configure.
- On a RIO module: Click I/O Channels > the digital channel > Configure
- Click the Quality Indication slider to disable the feature.
- Click Save.
