KB90420
Published: August 17, 2023
OPC UA client can't connect through firewall to OPC UA server on groov EPIC/RIO; server reports unrecognized client
- GRV-EPIC-PR1
- GRV-EPIC-PR2
groov RIOs:
- GRV-R7-MM1001-10
- GRV-R7-MM2001-10
- GRV-R7-I1VAPM-3
For groov EPICs: 3.4.0 to 3.4.5
For groov RIOs: 3.4.0 to 3.4.1
For groov EPICs and groov RIOs: 3.5.0
If the OPC UA clients connect to the Data Service OPC UA server on groov EPIC or groov RIO through a firewall router configured with port forwarding or NAT passthrough, you will see the following:
- The OPC UA client reports that it cannot connect to the Data Service’s OPC UA server.
- The Data Service reports that it cannot connect to the groov EPIC or groov RIO’s OPC UA Server and the Data Service log files contain a message similar to the following:
ERROR|2022-02-28 09:10:09,629|UascServerHelloHandler.java|224|[remote=/1.2.3.4:55566] Exception caught; sent ErrorMessage{error=StatusCode{name=Bad_TcpEndpointUrlInvalid, value=0x80830000, quality=bad}, reason=unrecognized endpoint url: opc.tcp://1.2.3.4:14840/Groov}
Contact Opto 22 Product Support for help with a workaround.
