KB90619
Published: July 28, 2023
groov View can't access tags on an OPC UA server
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
3.4.0 to 3.4.5
3.5.0
With this issue, you may observe the following behaviors:
  • In Build mode, when you click on an OPC UA device to browse tags on that server, the tag browser displays the message "Loading tags..." for an indefinite amount of time.
  • In View mode, attempts to read from or write to OPC UA tags fail.
Contact Opto 22 Product Support for help with a workaround.
