KB90902
Published: October 24, 2025
Analog channels from GRV-IVAPM-3 and GRV-R7-I1VAPM-3 not supported in PAC Display
PAC Display
All versions prior to R10.5c
R10.6a
When loading a strategy into PAC Display that contains analog channels from a GRV-IVAPM-3 module or groov RIO EMU (Energy Monitoring Unit; part number GRV-R7-I1VAPM-3), you may encounter an error message that the analog point objects cannot be loaded. Additionally, you may be unable to select the analog channels from the Graphic Dynamic Attributes dialog.
