SNAP-IDC-HDB-FM
SNAP-IDC-HDB-FM
OBSOLETE Fused breakout rack for SNAP 32-channel digital (discrete) input module
*** NOTE: This part is OBSOLETE and no longer available ***
Please consider SNAP-IDC-HDB or contact Opto 22 Pre-Sales engineers for more information.
The SNAP-IDC-HDB-FM breakout rack is used with one 32-channel digital input module, such as the SNAP-IDC-32-FM [Obsolete]. The breakout rack provides LED indicators and easily accessible fused connectors for input points.
Use the SNAP-HD-BF6 header cable for connections to the module.
For reference: Modules, Cables, and Breakout Boards Compatibility Charts
SNAP-IDC-HDB and SNAP-IDC-HDB-FM [Obsolete] Breakout Racks for High-Density Digital Input Modules
Used with
SNAP-IDC-32, SNAP-IDC-32-FM [Obsolete], SNAP-IDC-32N, and SNAP-IDC-32DN
Connectors
40-pin header connects to 32-point input module using SNAP-HD-BF6 header cable.
32 signal input connectors; each signal connector has a corresponding common connector.
For each zone of 8 signal inputs, 1 connection for either module common or field common.
Wire size for field connectors: 16-20 AWG
Indicators
1 LED for each signal input (32 signal LEDs total)
1 power status LED for each zone of 8 signal inputs (4 power LEDs total)
Fusing
1 A fuses; 2 fuses for each zone of 8 signal inputs (8 fuses total)
Replace with Pudenz 1 A automobile mini-fuse or equivalent.
Jumpers
For each zone of 8 signal inputs, 1 jumper controls whether module common or field common is used.
Voltage
32 VDC maximum, 12-24 VDC nominal
CE, RoHS, DFARS
SNAP-IDC-HDB Jumper Settings
This document shows the jumper settings for the SNAP-IDC-HDB, a breakout board for high-density digital input modules. Also provided are dimensions for installing the board.
Video: SNAP TEX Wiring and Mounting Accessories
A quick overview of SNAP TEX wiring and mounting accessories.
