SNAP-PAC-EB2
SNAP-PAC-EB2
$875.00 (USA and Canada only)
OBSOLETE - SNAP PAC Ethernet Brain, analog/digital/serial
NOTE: Due to the unavailability of essential parts, SNAP PAC EB-series brains have reached their end of life as of March 1, 2022. Instead, use a SNAP-PAC-R1 controller/brain; it has all the same features plus additional power (and programmability, if you need it).
The SNAP-PAC-EB2 brain is an I/O and communications processor for your control system. Designed primarily to work in distributed systems controlled by a SNAP PAC S-series or R-series controller, the SNAP-PAC-EB2 can also be controlled by a groov EPIC processor or used as intelligent remote I/O with Allen-Bradley industrial PLC systems. The SNAP-PAC-EB2 provides local intelligence that frees the controller (PAC, EPIC, or PLC) for supervisory tasks.
As an I/O processor, the SNAP PAC brain independently handles functions such as latching, thermocouple linearization, watchdog timers, and PID loop control. These functions continue to work on the brain even if communication with the SNAP PAC controller is lost.
The SNAP-PAC-EB2 brain supports all the SNAP I/O analog, digital, and serial input and output modules available on the Opto 22 website. These modules can all be mixed on the same mounting rack and placed in any position on the rack. The brain and modules mount on a SNAP PAC rack, which holds up to 4, 8, 12, or 16 modules.
NOTE: In order to use Opto 22 serial modules with an EB2 brain, the I/O should be controlled by a SNAP PAC controller or groov EPIC processor running a PAC Control strategy.
In addition to I/O processing, the SNAP PAC brain communicates over a standard 10/100 Mbps Ethernet network. The brain is equipped with two switched Ethernet network interfaces. Because these interfaces share a single IP address and act just like an Ethernet switch, SNAP PAC brains can be installed in a multi-drop (daisy-chain) configuration, extending the control network without the added expense of additional Ethernet network hardware. SNAP PAC brains can also be installed in a star configuration using standard, off-the-shelf Ethernet network components.
The SNAP-PAC-EB2 brain supports communication using multiple protocols running simultaneously over Ethernet. Most customers use the PAC Project software suite for control, monitoring, and data acquisition. At the same time, you can communicate using other methods, including EtherNet/IP, Modbus/TCP, SNMP, SMTP, FTP, and OptoMMP. Communication with OPC 2.0-compliant clients is available through OptoOPCServer. Additional programming options are available when the EB is used with a groov EPIC processor.
The SNAP-PAC-EB2 brain provides basic digital functions but does not offer high-speed digital functions; if you need high-speed counting (up to 20 KHz depending on the module), quadrature counting, pulse measurement, and frequency and period measurement, choose the SNAP-PAC-EB1 brain instead. For a complete list of features and specifications, see form #1689, the SNAP PAC Brains Data Sheet, under the Docs & Downloads tab.
Compare SNAP PAC controllers and brains.
If you are not using PAC Project software and a SNAP PAC controller or groov EPIC processor with this brain and instead need to communicate directly with it, see the SNAP PAC .NET OptoMMP SDK.
Ethernet and Serial Brains [Ethernet Brains are Obsolete 3/1/22]
Power Requirements
5.0–5.2 VDC at 750 mA maximum (does not include module power requirements)
Memory
16 MB RAM
Backup battery for real-time clock
Rechargeable (recharges whenever the brain has power). 5-year life when power is off (replacement part number: SNAP-PAC-BATTERY-ML2430). (Models manufactured before August 2007 have a 3-volt CR2032 lithium battery, available in retail stores. See original user guide for replacement steps.)
Hold-down screw
Torque: 8 in-lb (0.9 N-m)
Operating Temperature
-20 to 60 °C
Storage Temperature
-40 to 85 °C
Humidity
Agency certifications
-EB models: UL, CE, RoHS, DFARS; UKCA
-SB models: CE, RoHS, DFARS; UKCA
Ethernet Brains (EB) only
Ethernet Net­work Interfaces
IEEE 802.3 network, 10Base-T and 100Base-TX. Supports Auto MDI-X (crossover cable not needed). Two switched interfaces, allowing multi-drop (daisy-chain) or standard star network configuration.
100 meters with Category 5 or superior UTP
Serial Brains (SB) only
Network interfaces
RS-485, 2- or 4-wire, twisted pair(s), with shield
Serial data rates
300 baud to 230.4 Kbaud
Range: Serial multidrop
32 stations maximum on a segment (including PC, controller, repeaters, and I/O units); up to 3000 ft (914 m) on a segment
Using Modbus Devices with Opto 22 Products Technical Note
This technical note introduces the Modbus protocol and gives you basic information for using it to communicate between Opto 22 products and other devices. Because Modbus/TCP and Modbus serial are handled differently by various manufacturers, the tech note describes specific areas that may be a concern and includes troubleshooting suggestions.
This guide is a comprehensive introduction to the SNAP PAC System. The guide describes the system's components (software, controllers, I/O processors, and I/O); shows how to build a basic system and how to expand it; and includes installation instructions, wiring diagrams, dimensional drawings, and specifications for parts.
NOTE: Due to the unavailability of essential parts, SNAP PAC brains are obsolete and no longer available. Instead of Ethernet-based brains, use a SNAP-PAC-R1 controller/brain; it has all the same features plus additional power (and programmability, if you need it). For serial brain options, contact Opto 22 Product Support.
SNAP PAC brains are powerful and versatile I/O and network communications processors. Designed primarily to work in distributed systems controlled by a SNAP PAC controller, SNAP PAC Ethernet brains can also be used as intelligent remote I/O for groov EPIC systems and Allen-Bradley Logix-based PLC systems.
SNAP PAC brains provide local intelligence for functions such as latching, counting, thermocouple linearization, watchdog timers, and PID loop control.
This document covers the following SNAP PAC brains:
SNAP PAC Controller and Brain Comparison Chart
This document compares features of SNAP PAC hardware controllers (SNAP PAC S-series and R-series) and SNAP PAC brains, all part of the SNAP PAC System.
NOTE: Due to the unavailability of essential parts, all SNAP PAC brains are obsolete and no longer available. Use rack-mounted controllers instead of Ethernet-based brains. For serial brain options, contact Opto 22 Product Support.
SNAP PAC System Product Guide
PC-Based I/O Overview
This README file lists revision changes made to the firmware used in SNAP PAC S-series, R-series, and SoftPAC controllers; SNAP PAC EB-series and SB-series brains; and G4EB2 and G4D32EB2 brains.
SNAP PAC I/O Coprocessor Firmware README
This README file lists changes to the I/O coprocessor firmware available in rack-mounted Opto 22 controllers and brains manufactured starting in 2016.
I/O coprocessors can be present in the SNAP PAC R-series controllers, and in SNAP PAC EB-series and SB-series brains. Instructions to find out if your device has an I/O coprocessor are included in this README and in the PAC Manager User's Guide.
NOTE: The following products manufactured with I/O coprocessors have firmware R3.0a; you do not need to update the firmware in these products at this time:
  • SNAP-PAC-EB1
  • SNAP-PAC-EB1-W
  • SNAP-PAC-SB1
  • SNAP-PAC-SB2
IO4AB User's Guide
This guide provides instructions on how to set up EtherNet/IP messaging between an Allen-Bradley® Logix™ controller and Opto 22’s SNAP PAC I/O using Opto 22’s EtherNet/IP Configurator as well as Allen-Bradley’s RSLogix™ 5000 software.
EtherNet/IP for SNAP PAC Protocol Guide
This guide provides detailed descriptions of the EtherNet/IP commands that can be accessed when using remote Opto 22 I/O with an Allen-Bradley controller.
If you are using SNAP PAC controllers and SNAP PAC brains only, use Form 1704, PAC Manager User's Guide instead of this guide.
This guide shows you how to use PAC Manager to assign IP addresses, configure I/O, and inspect and maintain Opto 22 SNAP PAC hardware. PAC Manager is part of the PAC Project Software Suite and also available separately (part number PACMANAGER).
NOTE: If you are using older Opto 22 hardware in addition to SNAP PAC controllers and brains, use the Legacy Edition of this guide, form #1714.
SNAP PAC Brains User's Guide
NOTE: Due to the unavailability of essential parts, all SNAP PAC brains (EB-series) are obsolete and no longer
SNAP PAC brains, one of the four components of the SNAP PAC System, provide I/O processing and network communications for your distributed SNAP PAC System. SNAP PAC Ethernet brains can also be used as intelligent remote I/O in a groov EPIC system or an Allen-Bradley Logix-based PLC system.
This guide shows you how to install and use all SNAP PAC brains:
Modbus/TCP Protocol Guide
In addition to groov I/O and the SNAP PAC System, the guide also covers Modbus/TCP communication with older Opto 22 Ethernet-based devices, including SNAP Ethernet, SNAP Simple, and SNAP Ultimate I/O; and E1 and E2 brain boards.
OptoMMP Protocol Guide
NOTE: This guide replaced previous individual programming guides for SNAP Ultimate I/O (form #1312) and SNAP Ethernet I/O (form #1227). This document was formerly called the "SNAP Ethernet-Based I/O Units Protocols and Programming Guide."
Case Study: J.A. King
Whether it’s making sure grains are stored without excess moisture, weighing raw materials for chemical production, or batching and mixing ingredients for baked goods, automation is key to better results. System integrator J.A. King reduces costs for customers in a variety of material handling and mixing applications.
Case Study: Amalgamated Research, LLC
As the research and development department of Amalgamated Sugar in the 1970s, ARi began with a mission to develop efficient processes to extract sugar from sugar beets.
But over time, their continuous research in the industrial separation field has led them far beyond sugar.
Case Study: ISI Water Desalination
Once a haven for pirates, today Nassau and nearby islands host thousands of tourists. One essential is fresh water, and most resorts rely on desalination to provide it.
This case study follows a major resort whose desalination system needed complete replacement—without any break in service to the resort. See how ISI Water of St. George, Vermont, solved the problem.
White Paper: The Case for Intelligent Remote I/O
This white paper explores the use of intelligent remote I/O in industrial automation systems. Employing a distributed architecture, rather than centralized control, offers three advantages: minimizing single points of failure, spreading the load, and maximizing scalability.
The paper details applications that could be made more efficient by using built-in functions offered by intelligent remote I/O. It also gives a specific example of how distributed intelligence could be used in a PLC system.
Replacing the SNAP PAC Rechargeable Battery Technical Note
Several SNAP PAC controllers and brains contain a rechargeable backup battery. The battery recharges whenever the brain has power and retains data for an extended period of time with the power off.
You should never have to replace this battery, but if you do, this technical note shows you how.
Quick Guide: Troubleshooting Info from SNAP PAC Systems
This technical note provides a quick guide about diagnostic files to collect and send in to Opto 22 Product Support for analysis when troubleshooting a SNAP PAC System.
Using Intelligent SNAP I/O with Allen-Bradley PLC Systems
This technical note introduces SNAP I/O (brain, mounting rack, and I/O modules) for Allen-Bradley industrial PLC systems that use EtherNet/IP, including ControlLogix, CompactLogix, and MicroLogix.
The technical note briefly presents communication concepts, such as implicit and explicit messaging, and describes how to use implicit messaging to communicate with an A-B RSLogix-based PLC system.
White Paper: Adding Process Control to a PLC-Based System
This white paper discusses the strengths of traditional programmable logic controller (PLC) systems and distributed control systems (DCSs). The paper weighs methods of adding process control to a PLC-based system and proposes distributed I/O processing as the best method. It also introduces intelligent remote SNAP I/O, which adds process control analog functions.
Updating the Loader on a SNAP Device
It is rarely necessary to update the loader in a SNAP PAC controller or brain, but if you need to, this document shows you how. If you have questions, contact Opto 22 Product Support.
Expanding Allen-Bradley Systems with Intelligent Remote I/O (Chinese)
This white paper explores a new way to expand Allen-Bradley PLC systems, adding functionality as well as additional I/O, with less strain on the central PLC and little programming.
I/O Solutions for Temperature Monitoring (Chinese)
This white paper describes various temperature sensors such as RTDs, thermocouples, ICTDs, thermistors, and infrared sensors, and the Opto 22 solutions for using them.
Primer: I/O Solutions for Temperature Monitoring
This primer describes various temperature sensors such as RTDs, thermocouples, ICTDs, thermistors, and infrared sensors, and the Opto 22 solutions for using them.
EtherNet/IP Implementation in SNAP PAC Products
This technical note summarizes EtherNet/IP technology and how SNAP PAC devices can be integrated into an EtherNet/IP environment to send data to EtherNet/IP enabled devices such as Allen-Bradley PLCs.
Case Study: NASA - JPL
NASA’s Deep Space Network site in Madrid experienced a crisis when engineers detected cracks in the elevation bearings of a 230-foot parabolic antenna that enables 24/7 monitoring of satellites, space probes, and spacecrafts. These bearings support the 4 million pound weight of the antenna as it tilts up and down. To determine the precise nature of the problem, the antenna's bearings will be lifted and the existing shim pack removed and replaced with load cell transducers, which will convert the measured pressured into an electrical signal output and deliver it to an Opto 22 SNAP PAC System.
Specifically, SNAP-AIMA analog input modules will connect four sets of load cells (one for each set of bearings) to SNAP-PAC-EB2 brains, which will receive accurate load cell readings as the antenna moves across the bearings. NASA’s Jet Propulsion Laboratory will then be studying the data, formulating theories, and determining why the antenna’s bearings have been cracking.
Case Study: Ballarat Health Services
Ballarat Health Services in Victoria, Australia, is a major health care organization comprising two hospitals, convalescent homes, psychiatric services, six nursing home hostels, and rehabilitation centers. Ballarat upgraded from older Opto 22 M4 controllers and now uses Opto 22's SNAP PAC System for equipment automation and building management. Their broad set of applications includes remote monitoring, alarming, process and discrete control, and data acquisition for performance optimization, energy management, and regulatory compliance reporting.
Firmware for all SNAP PAC products (single download)
See the README document for information on changes and fixes in the current version of this product's firmware.
NOTE: Opto 22 recommends that you always use the most recent release of PAC Manager. Depending on the shipment date or the version number of the firmware currently installed on your SNAP-PAC-R or SNAP-PAC-S controller, older versions of PAC Manager cannot install certain levels of firmware:
  • As of February 22, 2022, some SNAP-PAC-R and SNAP-PAC-S controllers ship with new Ethernet components, along with PAC Firmware R10.4d (or higher) and new bootloader firmware to support the new components. PAC Firmware R10.4d (or higher) will not permit installing firmware lower than R10.4d on these controllers. To update firmware on these controllers, you need PAC Manager R10.4c or higher.
  • Effective April 2, 2018, some SNAP PAC controllers and brains have new flash components. These units shipped with firmware R9.5g (or higher) and new bootloader firmware. PAC firmware versions R9.5f and lower are not compatible with the new component. If you inadvertently install firmware R9.5f or lower on one of these units, you can recover by using the Failsafe Bootloader Mode to install firmware R9.5g or higher.
    • For more information about the new flash component, see KB87213.
    • For details on Failsafe Bootloader Mode, see "Replacing Damaged Firmware" in the PAC Manager User's Guide (form 1704).
  • To install PAC firmware R9.2c or higher on the following controllers only, use PAC Manager R10.4b (or higher), installed by either PAC Project 10.4002 or build 7 of the PAC Manager R10.4b installer. Wireless versions are not affected by this issue:
    • SNAP-PAC-R1
    • SNAP-PAC-R1-B
    • SNAP-PAC-R2
SNAP PAC EB-Series Bootloader
This download contains special firmware that upgrades the bootloader (or "loader") in SNAP PAC EB-series brains.
Starting in April 2018, some EB1- and EB2-series brains include a new flash component. These units have a hardware revision date of April 2, 2018 (or newer) and require bootloader R1.3b (or higher). For details, see KB87213.
SNAP-PAC-EB2 Brain Firmware
This download contains current firmware for the SNAP-PAC-EB2 brains. Current firmware for all SNAP PAC brains and controllers is available in a single download here.
NOTE: Opto 22 recommends that you always use the most recent release of PAC Manager. Depending on the shipment date or the version number of the firmware currently installed on your SNAP PAC controller, older versions of PAC Manager cannot install certain levels of firmware:
See the README document for information on changes and fixes in the current version of this product's firmware..
CAD 3D Drawing: SNAP-PAC-EB2 Ethernet Brain
This CAD file contains a 3-dimensional drawing of the SNAP-PAC-EB2 Ethernet brain, which provides I/O processing and communications.
CAD Drawing: SNAP-PAC-EB2 Brain
This CAD file includes drawings for the SNAP-PAC-EB2 brains, which provide distributed control for the SNAP PAC System.
Video: Dual Ethernet Interfaces: Controllers vs. Brains
A quick overview of Dual Ethernet Interfaces: Controllers vs. Brains.
Video: I/O Solutions for Temperature Monitoring
A quick overview on I/O Solutions for temperature monitoring.
Video: Using SNAP PAC System with Ethernet/ IP
A quick overview of how any device using the EtherNet/IP protocol from Allen-Bradley can communicate with Opto 22 SNAP PAC controllers and brains. More info: IO4AB
Video: Webinar: Controller Redundancy in PAC Control 9
Learn how to implement controller redundancy in SNAP PAC systems.
Playlist: Opto 22 I/O for Allen-Bradley
Learn about Opto 104AB using this playlist of videos.
PID: Reaction Curve Tuning for Interactive PID algorithms
Tune your real-world PID control loop with this graphical tuner. Plug in your data and get calculated P, I, and D values, plus scan rate.
SNAP PAC Networking
Learn the basics about dual ports, redundancy, segmenting, and daisy chaining of SNAP-PAC networking in this interactive demo.
