$935.00 (USA and Canada only)
SNAP-LCE
Processor
32-bit ColdFire® 5407
Memory Total RAM Battery-backed RAM Flash EEPROM
16 MB 512 KB 8 MB (7 MB with firmware version 7.2)
Backup battery
3-volt CR2032 Lithium, user replaceable. Typical service life with power off: 5 years.
Host communication
Ethernet (10/100 Mbps) or PPP (dial-up and radio modem)
I/O communication
I/O unit compatibility
Opto 22 SNAP Simple I/O, SNAP Ethernet I/O, and SNAP Ultimate I/O units
Serial ports
Two RS-232 ports. Baud rate is soft-selectable from 150–115,200 kBd.
Power requirements
5.0–5.2 VDC at 1.2 A
Operating temperature
0 oC to 60 oC
Storage temperature
-40 oC to 85 oC
Humidity
0% to 95% relative humidity, non-condensing
Software
ioProject software suite (ioControl, ioDisplay, ioManager) Purchase OptoOPCServer separately to communicate using OPC.
Other features
FTP server/client with file system Real-time clock
*** NOTE: Three products in this suite (IOPROJECTBAS, IOPROJECTPRO, and IOCONTROLPRO) are OBSOLETE and no longer available.*** This data sheet describes Opto 22's legacy ioProject software suite, which provides control and HMI development tools for a SNAP Ethernet-based control system. The ioProject suite includes ioControl, ioDisplay, OptoOPCServer, and ioManager. NOTE: For new development, use a SNAP PAC controller and PAC Project software.
The SNAP-LCE, part of Opto 22's SNAP Ethernet Systems family, is a older, standalone, small-footprint, industrial controller designed for use with SNAP Ethernet-based I/O units and ioProject software. It is used primarily in industrial control applications. The SNAP-LCE provides real-time control and is programmed with the included ioControl, a flowchart-based control programming software. NOTE: The SNAP-LCE and ioProject are not recommended for new development. For new development, use a SNAP PAC controller and PAC Project software.
This README file lists revision changes made to the SNAP Ultimate I/O firmware used in SNAP Ultimate brains.
The Allen-Bradley DF1 Integration Kit (Part # IOP-INT-ABDF1) provides users of Opto 22’s ioControl software(version 6.0 and above) an easy method of communicating with Allen-Bradley drivers or PLCs using the DF1 protocol. Opto 22 controllers can act as either a “master” or a “slave” device. They can be connected directly to the serial port on an Allen-Bradley PLC or to Data Highway networks using standard Data Highway interface devices.
NOTE:This document covers a legacy product which is not recommended for new development. For new development, we recommend SNAP PAC S-series or R-series controllers. The SNAP-LCE is a stand-alone, small-footprint, industrial controller designed for use with SNAP Ethernet-based I/O units. It is used primarily in industrial control applications. The SNAP-LCE provides real-time control and is programmed with the included ioControl.
This guide is for programmers who are writing custom applications to communicate with Opto 22 memory-mapped devices. These devices include groov EPIC processors; groov RIO modules; SNAP PAC controllers and SNAP PAC EB and SB brains; G4EB2 brains; SNAP Ultimate, SNAP Ethernet, and SNAP Simple I/O; E1 and E2 brain boards, and SNAP-LCE controllers.
NOTE: This guide replaced previous individual programming guides for SNAP Ultimate I/O (form #1312) and SNAP Ethernet I/O (form #1227). This document was formerly called the "SNAP Ethernet-Based I/O Units Protocols and Programming Guide."
ioManager is the software tool used to assign IP addresses and configure I/O points and system functions on most Opto 22 Ethernet-based hardware, including SNAP-LCE controllers: SNAP Ethernet, SNAP Ultimate, SNAP Simple, E1, and E2 I/O units; and SNAP-IT units. ioManager can also be used to directly read or write to these devices.
Quick reference card for using ioControl, including all standard ioControl commands and their OptoScript equivalents. ioControl is part of the ioProject software suite.
This command reference describes in detail all ioControl programming commands, or instructions. Use with form #1300, the ioControl User's Guide. ioControl is part of the ioProject software suite.
The ioControl User's Guide includes programming instructions and tips for developing control strategies to run on SNAP Ultimate controller/brains and SNAP-LCE controllers. ioControl is part of the ioProject software suite.
This document describes migration options for customers integrating the SNAP PAC System with older Opto 22 systems. It explains the SNAP PAC System's similarities and differences with earlier systems, defines legacy products, and shows how to mix old and new hardware. Customers moving to the SNAP PAC System may also want to consult form #1693, Legacy and Current Product Comparison and Compatibility Charts.
This document describes how to install a SNAP DIN-RAIL mounting assembly.
This download contains current firmware for the SNAP-LCE controller.
The Allen-Bradley DF1 Integration Kit provides users of Opto 22’s ioControl software (version 6.0 and above) an easy method of communicating with Allen-Bradley drivers or PLCs using the DF1 protocol. Opto 22 controllers can act as either a “master” or a “slave” device. They can be connected directly to the serial port on an Allen-Bradley PLC or to Data Highway networks using standard Data Highway interface devices.
This software application updates the internal clock for an Ethernet-connected Opto 22 controller. The application runs in Windows at the command prompt, and can update controller clocks regularly or just once.
This application is used with the following Opto 22 controllers:
A piecewise linear interpolator function PLI under ioControl 5.1. The ioScript version can be easily copied to your program. It can be used for any of the following applications:
