$110.00 (USA and Canada only)
ICTD
ICTD-P2 (OBSOLETE)
ICTD-P3
Features
Epoxy probe, non-immersion Suited for air temperature
Waterproof stainless steel probe Suited for air or liquid temperatures
Input Temperature Range
- 40 °C to 100 °C
Output
233 µA @ -40 °C 373 µA @ 100 °C
Sensitivity
1 µA/°K
Input Response Time (% of Span/Δ °C/ΔTime)
5 %/7 °C/7.8 seconds 20 %/28 °C/33.6 seconds 63.2 %/88.48 °C/150 seconds
Output Accuracy
±0.5 °C @ 25 °C. Factory calibrated.
Repeatability
±0.25 °C
Thermal Time Constant
2.5 minutes typical (still air)
Isolation
-- n/a --
500 V between metal shell and temperature element
Pipe Fitting Thread Type
1/4" NPT
Maximum Liquid Pressure
250 psi
200 psi
Maximum Cable Length
>2,000 ft. (610 m.)
Dimensions (nominal)
Overall length: 39 in. (1 m.) Cylinder tip: 0.7” (1.78 cm) L, 0.375" (0.95 cm) D
Lead wires: 5 ft. (1.52 m.) Probe diameter: 3/8 in. Probe length: 2 in. (5.08 cm.)
Lead wires: 6 ft. (1.83 m.) Probe diameter: 1/4 in. Probe length: 2.75 in. (6.99 cm)
30 months
ICTD temperature probes are temperature sensors used with Opto 22 ICTD analog input modules, including groov EPIC, SNAP, G4, and Standard (G1) modules.
This primer describes various temperature sensors such as RTDs, thermocouples, ICTDs, thermistors, and infrared sensors, and the Opto 22 solutions for using them.
A quick overview on I/O Solutions for temperature monitoring.
$163.00
$330.00
$296.00
$393.00
$630.00
$520.00
