$162.00 (USA and Canada only)
The SNAP-HD-CBF6 is a 6-foot (1.8 m) wiring harness for SNAP 32-channel digital and analog modules. The wiring harness attaches to the top of the 32-channel module and provides flying leads for wiring to field devices. The SNAP-HD-CBF6 is suitable for use with the following modules:
For reference: Modules, Cables, and Breakout Boards Compatibility Charts Build your system in the SNAP I/O Configurator.
Feature
SNAP-HD-ACF6
SNAP-HD-CBF6
SNAP-HD-BF6
Cable length
6 feet (1.8 meters)
Connectors
Two-cable assembly; 16-pin connector at module end; flying leads at other end
One 40-pin connector at module end; flying leads at other end
One connector at module end; one connector at breakout board end
Wires
Pre-stripped, color-coded, 22-gauge wires
Pre-stripped, color-coded, 24-gauge wires
24 gauge wires
Use with
Modules: SNAP-IAC-16 SNAP-IAC-A-16 SNAP-IDC-16
Modules: SNAP-IDC-32 SNAP-ODC-32-SNK SNAP-ODC-32-SRC SNAP-AIV-32
Modules to breakout boards: SNAP-IDC-32 to SNAP-IDC-HDB SNAP-ODC-32-SNK to SNAP-ODC-HDB SNAP-ODC-32-SRC to SNAP-ODC-HDB SNAP-AIV-32 to SNAP-AIV-HDB SNAP-AIMA-32 to SNAP-AIMA-HDB
SNAP TEX cables and breakout boards are part of the SNAP TEX family of wiring and mounting accessories. These parts save time and expense during installation, maintenance, and debugging by reducing the time and effort required to wire field devices to SNAP I/O modules. This data sheet covers the following part numbers:
A quick overview of SNAP TEX wiring and mounting accessories.
$278.00
$452.00
$411.00
$1,381.00
$128.00
$200.00
$1,295.00
$451.00
$484.00
$198.00
